Testing and Results
We measure the CPU temperature of our test rigs when the CPU is idle (Windows desktop) and under load (by running the smallfft test in
Prime95). We use the freeware application
CoreTemp to measure the temperature of the Intel CPUs, which reads the data from the DTS (digital thermal sensor) embedded in the core of every modern CPU. The DTS gives a far more accurate reading than any third-party temperature sensor, because its readings are not affected by sloppy BIOS programming or a poorly calibrated external health monitoring chip on the motherboard.
Because we don't have a temperature control chamber, it's more accurate to measure and quote the delta T (difference) between the ambient and CPU temperature. This means HSFs (heatsinks and fans) that were tested on different days, when the ambient temperature may have varied, can be fairly compared to one another. You'll find the temperature results for the reference HSFs in the graphs. We normally compare the results of each cooler to the reference cooler.
LGA1155 test system:- Core i7-2600K overclocked to 4.1GHz using a vcore of 1.325V
The test rig is built inside a SilverStone PS03 midi-tower case and includes an Nvidia GeForce 9600 GT graphics card. The temperatures shown are the delta T between ambient and CPU temperature.
Each test rig is built inside a SilverStone PS03 midi-tower case and includes an Nvidia GeForce 9600 GT graphics card. The temperatures shown are the delta T between ambient and CPU temperature.
Antec Kühler H2O 920 (Extreme Profile)
Corsair H80 full speed
Corsair H100 full speed
Corsair H100 medium speed
Corsair H80 medium speed
Arctic Freezer i30
Be Quiet! Dark Rock Pro 2
Phanteks PH-TC14PE full speed
Be Quiet Dark Rock Pro
Corsair H100 low speed
Corsair H80 low speed
Phanteks PH-TC14PE low speed
Be Quiet! Dark Rock Advanced
Gelid GX-7
Gelid Tranquillo Rev2
Thermolab Trinity high speed
Antec Kühler H2O 920 (Silent Profile)
Thermolab Trinity low speed
Phanteks PH-TC90LS
Arctic Freezer 11 LP
Intel Reference Cooler
20
30
40
50
60
70
80
Delta T (°C) (lower is better)
*Please note that due to the fact much more potent coolers have failed to cope in our LGA2011 test system, we've only tested the PH-TC90LS in our LGA1155 test system.*
Head
over the page to see the performance analysis and scores
